First off thanks for those that contribute to this forum, It's helped me immensely iron out some wrinkles on my boat.
Like some others on the forum I am having a problem with my boat losing power when I have it loaded and I'm making sharp turns. In smooth water and going straight it never slips, but pretty rough water, or especially pulling a tuber aggressively it slips.
I have a 21i 2002 Tige with the 350 5.7 engine and the velvet drive transmission.
steps I have done to remedy the problem:
1. I've changed the fluid in the transmission and checked the levels. There is mention of a bulletin for a different than suggested in the owners manual method for measuring calling for a different level of filling and checking. These link are broken, and I was unable to properly view the bulletin. If someone has an active link to this I'd love to have it. At any rate I've measuring while hot, puting it in forward then reverse and measuring and such, which was suggested in other forum posts to no avail.
2. It was suggested that it might be prop cavitation, so I inspected the prop, it indeed was dinged, so I was excited this might be the issue, cheaper fix than a new tranny. I replaced it with the prop that acme rep suggested personally for my boat ACME 1231 3 BLADE 13" X 11" PROPELLER. After I put the prop on the boat responds great but still slips in tight turns pulling a tuber.
Has anyone else solved this? Thanks in advance
