I have a 1998 350 mericruiser, I have replaced the fuel pump and starter and all new spark plugs. I can start the boat but only when I give it throttle. It will fire for a bit but then it dies out. I can keep it going if I work the throttle, but it seems to not getting enough fuel I can see the injectors working. I have used additive and a new fuel filter to. Any idea??
1998 dies out
Assuming its an MPI engine since its a 98. The distributors are known to be a replacement item I'd make sure there is no corrosion on it, as well as spark plug wires. I'd also check timing. It's pretty simple to do on these engines, just put it in the diag mode. If you don't have the tool just jump wires, like this tool would (https://www.amazon.com/Mercury-quick.../dp/B004QJMYIW).
Always run ethanol free gas too, much much better performing when you do.
