I have quite a bit of belt dust on alternator and in engine compartment. It appears the alternator pulley is a different size(the dividing line btwn the two belts is thicker on alt than all others). You can see in pic the back belt is aligned but front(rear of boat) belt is proud at alternator.
Does anyone know if this is enough to cause this prob?
I also see water pump pulley has rust.
I sanded the crank pulley already. I’ve tried shimming with a washer. I’ve also noticed it’s missing the spacer part #244501 from MP Parts Manual.
Or do I just need to crank down and tighten alt. belt more? No belt squeal just dust...
I’ve had it a year. Using Napa xl 27-7450 belts. Any ideas?
