After tracing all the wires the negative/ground wire from the taps module appeared to possibly have a worn coupler combined with being daisy chained to another gauge. I disconnected the wire from the ground altogether and the symptoms were the same as it not working intermittently (taps gauge flips from 7 to 1 and taps doesn’t respond), so I may have replicated my intermittent issue... knock on wood. I also read in other threads that taps module likes a “clean ground” given that, I chose to route the negative wire directly to the negative dashboard bus.
all appears to work currently, I’ll update again if the issue returns.
