I just bought a 2019 Tige RZX3 with about 130 hours on it. Yesterday after surfing right side we stropped and changed some weight around to switch to left side. The boat would not start again. We kept checking the throttle to make sure it was not in gear and wiggled it back and forth while trying to start but nothing. There were no beeps when you turn the key and the starter was not trying to do anything. When I pressed the button and moved the throttle forward the blue light would come on. When I turned the key to on it would glow brighter blue. But if I turned the key to start nothing happens. I have only had the boat a few days and the previous owner said they have never had any issue like this with it before. We turned off the batteries a couple of times and cycled the screen on and off several times as well. The batteries still show 12.5-12.8 volts and the boat was running on the main battery only so the starter battery was not being drained.
Any ideas where I should start to try and get thing running again? The local dealership can't look at it until next week at the earliest. The boat is under warranty so I don't want to explore too deeply on my own but wanted to see if there is a known issue or if others have had this same problem?
