At a total loss here being semi mechanically inclined.. 08 Z1 with MP 5.7L.
Had an issue with fuel pressure not being up to par(10-30psi), changed the high pressure fuel pump cartridge as the low pressure pump was working correctly (verified at the high pressure pump while changing it out). Fuel pressure now reads a steady 55-60psi while running And under throttle on the fake-lake. While I had the tools out I changed the plugs, distributor cap and rotor and the 4 relays by the ECM.
Got it on the water thinking my vapor lock/rough idle was fixed.. sure enough, same problem. Launch the boat and fires right up and runs great at idle and in gear, putt around the no wake zone and wait for the ole lady to get to the dock to get her, mind you, running my bilge blower constantly. Pick her up and get to open water(motor is warmed up by now), give it throttle and it falls on it’s face and starts idling rough and kind of surging. Put it in neutral, starts to run rough and eventually dies out. Try starting again and nothing.. probably try about 10 times before it sounds like it wants to run and still nothing. Operating temps are normal(140-145) the fuel looked good when I got some out of the fuel pump. I’m stumped. Any guesses on what it might be?
edit: was doing the exact same thing before changing the high pressure pump
