Dropped the boat in the water yesterday and went to fire her up but no joy - got the usual lights, alarms, and pump runs with the switch in the "ON" position, but when moving to "START" there was no click at the starter. TT screen and gauges went off (like usual as I recall) during start attempt then came back on. Moved the battery switch to combine but got the same results. Checked connections and voltage at the cranking battery (~12.5) and at the starter (~12.4) with a tester. Tried jumping at the cranking battery - same results. Whacked the starter a few times with a wrench and she fired up, although not with its usual gusto. More like a half-hearted start... like maybe low amperage? Both batteries are less than a year old - no issues the last time out 2 weeks ago. I put both batteries on a charger for a few hours, but again got the same results when attempting to start. Tapping on the starter worked several times during testing, but always with a less than enthusiastic effort from the starter. Is it dying? Could something else cause it? Anything else to try before ordering a new starter? Thanks in advance.
Boat is a 2013 Z1 with PCM 343 (~285 hours)
