I have a 2016 z1 with 220hrs. It’s not getting fuel. Turns over but won’t crank. Has happened several times this summer and later would fire up. Not this time. Any suggestions besides the fuel pump? Is there a relay? I listen for the fuel pump to engage when I turn the key but I am having trouble hearing over the other beeps and so forth.
Fuel Pump?
Take the beauty cover off engine and there is a fuse box and some relays on top of the engine that are labeled on their cover. Good place to start.
Fuel pumps kick on when ECM wakes up via purple wire from Ign switch.. so if you have a meter and can verify 12v at key, 12v at both sides of kill kanyard and 12v at engine harness plug ECM ""should" be powering up.
