Perfect pass ...Help please..
    I replaced my rotor on my motor and first trip out today the motor ran great, but perfect pass didn't. It would get to the desired speed (23mph) beeps, and didn't hold speed. I don't think the new rotor caused the problem, but not a 100% sure. I think it might be the servo motor went bad. Is their a test i can do to test this? Could it be a spring problem? Help!!!!!!!
    Probably a loose connection on the servo or servo itself.
    try to turn the black knob on the servo motor. If it doesnt turn your servo is seaized and you need a new one. But if it turns freely it could be a loose connectiong.
    When you turn the boat key the system should do an auto tighten, you will see the knob turn.
    Common Sense is not so Common
