Help
    Help
    Spring break and my 09 RZ2 won't start. The batteries are charged, the accessories work, but no juice to the ignition. Also, the circuit breaker doesn't appear to be getting power as all the individual breakers are as limp as a 70 year old man with no viagra. Help!!!!
    Your E Stop switch is in Run Right?
      Yes, its forward towards the dash.. Is there another breaker besides the one under the dash?
        Is the ON/OFF switch back by the battery(s) on? Are you sure both batteries are charged, especially the deep-cycle accessory battery?
        Where the batteries removed for charging and storage? If so, double check that a ground or positive cable didn't get overlooked
          If you mean the on off switch that is in the same compartment as the battery box, yes, its on. I didn't take them out for the winter because we are in Houston and winter is not that long. Where can I get the fuses that are on the engine?
          Thanks for the help.
            Where can you get the ignition relay fuse?
              Check the circut breaker just about the batteries. It feeds all the stuff at the Helm! I have an 09 RZ2 and the nut backed off of mine and I had no power up there. You may have to get down in the side hatch to be able to see it!
                Just checked and mine wont start if that breaker is tripped or unconnected! The display on the dash will light up but it won't start! So that Breaker above your batteries could be your problem. If there is a little red bar showing, just push it closed and the breaker will be reset!
                  Any luck here?
                    I can't find the breaker. I don't have any lights or power to the ignition but my accessories work. Can you email a picture of where that breaker is? I understand if its too much trouble and thanks for your help so far.
                    Randy Goss
                    randygoss@allstate.com
                      LOL< our boats are the same colors if your picture is your boat. Nice boat.
