just bought a 1999 pre 2002. Is there an in tank fuel pump or only the booster in line after the water filter? I am not getting fuel to the engine and trying to trouble shoot it. I know no fuel is getting to the water filter. Any thoughts are welcome.
Fuel pump
Originally posted by vault614 View Post.... I know no fuel is getting to the water filter. ...
There's a check valve in that fitting that may be clogged.
Our 350 Mag MPI only has an electric fuel pump under the side of the engine.
When you first turn the key on it should hear it trying to build up pressure in the fuel lines.Attached Files
