So I took my boat (2000 2100V) out last weekend, and everything ran fine and no problems. I've not hit anything in the water or anything that I know of. Took the boat out yesterday, and noticed a smell at low speed as I was pulling away from the ramp. Smelled like a hot engine, if you know what I mean. Didn't smell gas, or oil, and saw no smoke. The temp. gauge showed real hot, 3/4 of the way along the guage, I believe 250? So I got it back to the dock, and let it sit for 15 minutes. Turned the key to see the temp, showed 1/2 way (175 deg), tried to turn it over, but it made a real loud clunking noise, which made me not want to even try turning it over again. Any ideas? I looked at the prop, didn't notice anything seriously wrong, but if you have any inklings, don't rule it out. From what my prelim research has shown, its either an impeller gone bad, or the water pump maybe. I haven't changed either, and don't know how long it has been since either has been changed. The engine is a Mercruiser 350Mag MPI. Oil dipstick had clean oil on it. Please help fellas, not many weeks left in the season. Anybody around here in OKC or Norman want to help with the install, if it's not too tough? Usual install help necessities will be present, food, drinks, you know
Ryan
Ryan
