Hello,
Looking for some guidance. 2006 24VE 340 horse Marine Power with 60 hrs. Get boat out this summer to get ready for season. Found rain water had accumulated under the engine and in the valley of the hull. Maybe up to bottom of oil pan. Drained the water out, checked all fluids (good with no milky consistency)installed new batteries and ran in driveway with hose. Boat ran good for approximately 20 minutes then idled down and sputtered until it died. Attempted to start again, but it would not start again. I let it sit for about 2-3 minutes and it started and then ran for a moment and did the same thing. I can hear the fuel pump on the side of the engine "prime" and then stop after about 15 seconds when the key is in the on position. When it does run, the engine sounds like it's "sucking for air" when it does die like it's starving. Could water contamination be the culprit? Not sure if this model has a separator, if so any clues on location and servicing it? Any help or suggestions would be greatly appreciated. Note: first time in forum.
