Does anyone else have problems with their fuel guage? Not just with the sloshing around either. When I fill up, the guage shows full, and it will remain there for an hour or so of use. Then it will sometimes show around 3/4 tank, but will likely show empty. It's usually not a big deal...I just fill up every other use.
Just wondered if y'all were getting semi-accurate readings from your fuel guages...
I took the boat into the dealer after the first couple of outings to get it fixed. He said it was likely sticking and opened it up to work on it. Well, he didn't fix it...and then the dealer folded!
And that brings up another question...where in Houston is a good place to get my Tige serviced? I'm in lower Houston and don't necessarily want to drive to Conroe or Austin... (when are they going to sell Tiges in Houston again?!)
