I have a 2002 20i and the throttle/shifter became loose. After taking it off and putting back on and tightening the set screw on the bottom the Taps trim does not work. Does anyone know if the electrical connection in the shift assembly needs special attention when the shifter has been removed?
Thanks,
Jeff
Thanks,
Jeff
