Looks like new dogbert! I used the Snappy Teak last summer after seeing your thread and it worked great.
Transom & Platform restoration
I sanded my platform this spring before getting it out. I recommend a good sturdy hand sander (with a handle) and starting with a light 60 grit wet sanding to remove really bad nicks (I had a few), 80 grit wet sanding to level it out, another 100 grit wet sand, then a 150 wet sand. After washing and drying, I applied a teak oil coat with a diaper. I let that dry 24 hours and wet sanded with 150, dried, oiled, 24 hour dry then repeat. After this last coat dried I went to a 320 grit and did this process 2 more times.
A good week and a half, but I love the look.
I wasted about 3 days with a palm orbital sander. Nothing beats elbow grease. There is a guy here that builds platforms for Mastercraft that I had to go get a piece of replacement teak from. He recommends not going finer than 320 grit or you will have 4 year olds slipping off the platform and floating down river, like I did the first day out.
