light on dash trans oil.stays on all the time oil is fresh and full to proper level on dip stick
I have a problem
It says "Trans" but I believe it is actually for the V-drive fluid pressure. Are you able to check the fluid level with the boat sitting level in the water?
Gotta ask......you are positive this was not a problem before the service and did you use the correct fluid?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
When we got our boat it was 6 years old and it had sat for 2 years.
The "TRANS" light (V-drive oil pressure indicator) was stuck on all the time, too.
The switch was gummed up inside.
Our V-drive is the Walter Gear Drive RV-26D, Ratio 1.46-1.
It uses a Hobbs Corp. - 76061 pressure sensor, 2 psi, NC.
Here's a spec sheet - http://www.fdrive.com.au/products/05/pressurep.php
