Originally posted by Double A
View Post
More antifreeze talk
Originally posted by Double A View PostIs putting the bulb under the engine cover the only you do to winterize your boat? I'm in TX and it really doesn't get and stay too cold.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostA bulb in the engine bay is only a method of preventing the block from freezing, there is a lot more to winterizing: Fuel stabilizer, oil change, transmission fluid change, V-drive oil change (if you have one), lube steering cable in grease rudder box, charge battery(s), clean and dry boat, including bilge and storage, drain or add Marine/RV antifreeze to ballast system, if equipped, service trailer bearings and seals, lube coupler, top off brake fluid..........Did I miss anything?
