Ok guys, it's getting cold up here in the midwest, and now I'm getting a little nervous. I winterized my boat about a month ago, I think. I initially pulled it out of the water, drained it, and ran a bucket of antifreeze in it. . I then took out the plugs and let it drain again. I couldn't find a plug o the driver side block at that time. Very little came out of the passenger side block drain. It came pouring out of the manifolds and was very hot. About two weeks later, I went over to where I have it stored, and I found the plug on the driver side block. I pulled the plug and it was basically dry. So, I put the plugs back in, hooked up a bucket of antifreeze and ran about 10 gallons of antifreeze through it. I drained, and very little came out the passenger side block, and a few drips came out the driver's side. I repeated this process and again, very little came out of the block. Basically none on the driver's side, and only a little stream on the passenger side. I caught the bit from the passenger side in a cup, and it was pink. That made me feel good at the time, but now that it's getting cold, I'm getting a little nervous. Is there a good reason there shouldn't have been more fluid in the block? Also, i hear people saying to take off the upper hose and dump antifreeze down it. are you disconnecting at the top of the block right by the thermostat, or are you disconnecting it down off of the housing that the intake hose from the thruhull is on?
Thanks
Thanks
