I took the prop off with a puller to clean it up and to make sure I could get it off. Do I put Never Sieze on when I reinstall or do I put it back on dry?
always put them on dry. the never seize will not allow it to seat properly.
this could cause the prop to come loose. i've seen a loose prop break a propshaft in two.
Greg Denton
Another prop question.
Should I have my prop balanced?
I have a 100 hours on it and I do not think that I ever hit anything,
When I look at it I do not see any damage.
I will be taking it in to Tige water sports on the 8th for some work, so I was wondering if I should add this to the things that need to get done.
