Oil question
    Oil question
    My 05 Ci Engine manual states wrt oils...
    5.7L/350CID
    Marine Power does NOT recommend the use of multi-viscosity, non detergent type oils. Oils that contain solid additives or low quality oils0other than 20w-40 20w-50) are also not recommended.
    The chart sez...below 32 20w...32-50 30w..above 50 40w
    Since our temps vary from 20 to 100 over the course of the year, I find this to be a bit confusing. During winter storage (inside non heated) it certainly can reach 20.
    In the boat, I have 20w-40 for the past year as recommended by my local boat dealer (non Tige dealer).
    Is 20W-40 the proper type?
    TIA, Paul
    I honestly don't think the weight is going to matter if you aren't turning it over. I think in certain conditions, the engine has a harder time turning over with heavier weights of oil. If it's just sitting, I don't think weight will matter.
      Do you ride when it's 20* out?
      The first number is the cold engine start-up viscosity, the 2nd is the warm engine viscosity. If you ride when air temps are getting low, then a multy-vis with a lower 1st number is best to give good pumpability and lubrication when starting cold. If you ride only when it's Summer time temps out, the a single weight is fine.
      Storage should not play a roll in oil viscosity.
        You last sentence sums it up. Thanks! And no, at 20, the lake is frozen
        I'll continue to use Merc 20W-40
          Oil changed done! I would like to SHOOT the engineer that decided to place the oil filter under the engine with limited to NO area to work
            Be thankful you don't have a V-Drive.
              you can install a remote oil filter housing kit that will eliminate that whole hard to get to headache, and I second the motion, be glad you don't have a V drive.
              I don't want to go to work, take me wake surfing instead!
                Mine is easy to get at. It's almost in from of me when I open the starboard side engine wall.
                  I'll take my V-drive any day, pull of the side-wall and BAM, it's right there
                    Where can/should I pick up the "remote oil filter housing"?
                      Yeah especially a Merc v-drive like you have with the mufflers also in the way. Almost as much fum as the drain plug on the fuel cooler.
                        flyboy
                        where do you get 20-40 oil? I know of 25-40 that merc sells but have not seen 20-40 oil for at least 15 years made by anyone. I know it was around in the 70's.
                          He probably means Synthetic Blend MerCruiser Engine Oil 25W-40.
                            they also make regular oil that is 25-40
