Originally posted by illiniboarder88
View Post
"The Pink Stuff" vs Draining
Anyone one with ballast system? Ive read elsewhere suggestions on just pouring the pink stuff down the 'outflow' on all four ballasts...but what about the input side of it?
I have my thoughts of just hooking a hose to the inlet (located in the back under the swim platform, 2006 22v) and turning the pump on to suck some up...but curious if anyone has any better ideas?
Originally posted by Timmy! View PostIf the ballast is empty, why would you worry about it? Sure there's going to be a little bit of water leftover in it but when that tiny amount freezes, I don't think it's going to expand enough to do any damage.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
There was something else that I was a little confused about. I read from the maintenance manual that during winterization, pull the engine oil & transmission cooler plugs. however I did not see any drain plugs on this unit. Unless I was looking at the wrong thing. It was basically a 8inch or so metal tube that ran inline with my raw water inlet (5.7L efi). Do you suppose they are referring to disconnecting the hose? or is there and drain plug that I just missed on this unit.
Originally posted by off2board View PostThere was something else that I was a little confused about. I read from the maintenance manual that during winterization, pull the engine oil & transmission cooler plugs. however I did not see any drain plugs on this unit. Unless I was looking at the wrong thing. It was basically a 8inch or so metal tube that ran inline with my raw water inlet (5.7L efi). Do you suppose they are referring to disconnecting the hose? or is there and drain plug that I just missed on this unit.Originally posted by Timmy! View PostThere is a drain plug on the side of that cooler that you are referring to. I just disconnected the hoses last year but this year I have decided to run pink stuff since my heater core ruptured even after I thought I had it drained.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by off2board View PostYour heater core ruptured? Arent the hoses connected to the trans/oil cooler oil?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I just winterized today and here is how I did it:
1. Ran engine to warm up.
2. Sucked out oil through dipstick
3. Replaced oil filter and fuel / water separator
4. Restarted engine and warmed up for 7 minutes at 2000 rpm
5. Hooked up 4 gallons of pink antifreeze to fake lake
6. I start the engine, turn the shower on and let it suck all 4 gallons
I did not blow out the heater core - I am hoping that the pink stuff made it up there. Any thoughts or comments?
Originally posted by Moki View PostI just winterized today and here is how I did it:
I did not blow out the heater core - I am hoping that the pink stuff made it up there. Any thoughts or comments?Common Sense is not so Common
