I have winterized my boat 2000 20i for three years now, never a problem, but, I thought I would read up on it on this site and I came across a few questions...
what i do, is...1)fill the tank with the appropriate amount of stabil...2) when I am pulling it out of the lake for the last time and it is on the trailer on the boat launch in nuetral, spray in fogging oil while running when is it at idle and at higher RPM's...about 1/2 a can 3) drain the block by removeing the 5 blue caps, then I remove the 4 hoses on the top of the engine pour down the pink antifreeze into each of the 4 hoses (envirementally friendly, I guess) until it pees out the drainholes...it really only takes 1/2 gallon of antifreeze, if that. 5) Oil change and new oil filter...I consider it done.
I read that some people spray fogging oil into the spark plug holes, also, I read that some boat owners use up to 2 gallons of antifreeze, (is that with the blue caps replaced in, thus making it a closed system once again) and I see that a lot of boat owners change the impeller and fuel filter each year. I did change my fuel filter this spring but have not changed it since '04, no problems with it ever, and have not changed the impeller since I bought the 20i in '03. Is the 2 gallons of antifreeze really necessary and fogging the sparks plugs holes necessary. Why would the impeller need to be changed. I guess I could be convinced to do the fuel filter annually, if there is a strong argument for it.
Also, I see that some lubricate/grease the rudder and check the tranny fluid...that I can certainly add to my list.
Does anyone have any issues with my way? Any suggestions, so far so good in the MN winters..Thanks
