What is the best Teak Oil / Treatment for the Swim Platrom?
Teak Platform
ahem..
Swim Platform Care.. Found in the Maintenance and Care section.. On the bottom of each forum section is a drop down to show posts older than 30 days.
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
Rhinoliner!
It's maintenance free and protects against warping which sometimes occurs in extreme heat. My 2002 21V had it and I absolutely loved it. I don't have time to wax my boat often enough let alone invest more time in the swimstep.
My new boat has fiberglass and I find it pretty good as well, but I actually liked the laminated teak a little better.Be excellent to one another.
My father had sail boats for many years and he always used crude linseed oil but it isn't esy to find. On my Tige I have used the StarBright product and it has done a good job so far.
The rear ramp is so small that the cost X treatment is relative. It becomes a cost issue when you have the whole deck to protect so if you know which one is the best, I would go for it !!
Good Luck
I saw a demo @ the O.C. Boat show this past weekend for a product to clean and seal the teak swim step. The product seemed easy to work with. Spray it on, hose it off. Wait 24 hours. Seal it with their sealer and off you go. I'll take a before & after picture and post them when I do the job.
The products name are WOODBRIGHTENER and WOOD SEALER. The man selling the product was not some blaring salesman with a microphone. It was an old man, very confident and passionate about his product. His name was Gordon. I can only assume he is the Gordon of Gordon Feron & Co., Inc.
It appears from their website they distribute it through local patio and boat stores as well as from their own online store. Try the store finder on their website.
I Posted this once before, but here's my whole teak care procedure.
This is what I do:
1: Take the swim platform off the Boat
2: Have a beer
3: Pressure Wash platform, top and bottom
4: Let dry, have a beer
5: Sand entire platform with 80 grit
6: Have a beer
7: Touch up any really rough spots with 120 grit
8: Have a beer
9: Wash off sanding dust
10: Let dry, have a beer
11: Apply teak oil
12: Re-attach platform
Usually takes me 2 hours or so, I wonder how I could ever speed this up? My wife thinks it takes way too long.
80 and 120 are all I use, I'm not trying to get the platform really smooth. i.e. slippery when wet, just raise the grain and take off some of the scratches"I want to know God's thoughts, the rest are just details"
I'm thinking I like the look and feel of teak much more than Rhinoliner...
Here's my process...
When it starts to look like it's drying out, I do the following
1. remove from boat and make sure it's level on the ground with newspaper under it. (2 minutes)
2. Liberally pour teak oil on it. (30 secs)
3. Use a paper towel to wipe teak oil all over the top and sides (1 min)
4. Let sit to soak in (10 min)
5. Wipe off excess and reinstall on boat (2 min)
So that's about 15 minutes with 10 of those minutes doing something else while it's soaking in. If you do this regularly it shouldn't need sanding. I only did that once to get the sealer off which looked horrible as it wore off.
When it's kept fresh like this, I don't even notice scratches.
Easy and quick! (And it looks good and feels good on the feet)
Mike
