2003 23 V Tranny
    2003 23 V Tranny
    I'm feeling some slippage when pulling a wake boarder. I believe I need to add tranny oil. does anyone know how to access the transmission?
    The only reason you should need to add tranny oil is if you've lost some..., or if it wasn't filled at the last change. Anyway, if you have a velvet drive the combination dipstick filler tube is on the starboard side of the transmission about straight down at the front of the engine compartment. You unscrew a T-handle on the top of the dipstick a couple of turns and pull it out. 'least that's where it is on my '02 20V.
