WHAT IS THE BEST OIL TO USE.......
    IM GOING TO CHANGE MY OIL ON THURSDAY, i have the 5.7L 340hp, gm vortec 07'? and exactly how much, i havent checked the dipdtick length length yet?
    thanks
    If you change the filter use 5 quarts.
      i use a syn blend 15w40 (Kendall) and as Lee said 5qts. napa gold oil filter#1069.
        thank you very much
          If you really, really love your engine, pay the extra $$ and order Amsoil filters. Otherwise, I recommend K&N. The synth blends are a good way to go... Mobile Clean 5000 is a blend and so is Clean 7500 I think.
          RW
            I am also going to change the oil this weekend... I have a 1999 with the Mercruiser 350 MPI, 315 HP... How much oil and would you guys have the same oil recommendation? Anyone know the filter part number off the top of your head?
            Thanks
              Take a look at this in depth oil filter breakdown, shows which are good and which to avoid. http://www.knizefamily.net/minimopar.../opinions.html
                I use a Fram TG30 filter on our 2000 Mag MPI.
                  Great R&T - about how many quarts?
                    Five quarts of 25w40 oil.
                      Thanks. What a great board this is... kinda makes we want to buy a Tige... oh yeah, I already have one!
                        OIL ?
                        I just purchased a new Z1 and the owners manual calls for NO muligrade oils. They say use straight 30W or 40W depending on the temp. Anyone have any thoughts. it's a 5.7 325hp
                        Thanks for the input, break in is over, time to do the first service.
                        Bob
                        bobg
                          We use Penzoil Marine 15w40.
                            Thanks
                            I have an excel file w/ oils, filters etc w/ p/n's if you need it.
                            25w40 oil w/ a moisture inhibitor.
                            Dale
                            2000 21i Tige
                              Fit TO BE TIGE
                              The following are oil filters that you can use
                              FRAM PH30
                              AC PF25
                              Purolator L20049 Proline @ pep boys is the same number is made by purolator
