Originally posted by geomaster
View Post
I ended up using almost 2X the new part2 as I did part1. I feel it was my own doing, and now I understand why. This platform was neglected and looked pretty rough. I wanted to clean the underside just a bit, so id started with it first. Once I was done and flipped the teak over to do the topside, I found that the part1 had run down to the topside and "stained" it while I had it upside down cleaning the underside. I went ahead and cleaned the topside per the instructions, but it took a lot of part2 to get those dark spots to lighten up.
So, in hind-sight, I would recommend that the underside NOT be cleaned with this stuff, just a good pressure washing fallowed by a coat or two of oil once the whole deck is cleaned and dry. One other thing I learned. Get a couple of spray bottles from the dollar store and put the part1 and part2 into them. Misting the cleaners on makes for better coverage and less wasted product.
I would use this system again and would recommend it. Good luck with the dark spots.
