I picked this up at my local dealer. It comes with 2 brushes and two bottles of cleaner.
The brushes are color coded to match the liquid in the bottles. The directions are pretty easy to follow and you definitely want to follow the recommendation for wearing rubber gloves. Both solutions are nasty, even when diluted.
Here's the platform when I started:
You want to make sure the platform is dry when you start.
First you start with the darker solution. It will actually lift out all the Teak Oil you have applied in the past. I diluted mine at first because my platform wasn't too bad. Immediately after applying and rinsing the first solution, you apply the second. The directions recommend keeping them separate and using separate brushes.
You can see a couple of spots where I had to go back and use the first solution undiluted. But, overall, it came out looking like fresh teak.
Once dried, I applied Premium Teak Oil. The premium appears to work more like the teak oil you use for furniture and less like varnish. This results in a beautiful finish. I had to apply the oil twice and here are the results:
I definitely would recommend this product.
