How often should one oil their swim platform and what type of oil should be used and what type of preparation work needs to be done?
Swim Platform Care
Originally posted by Tip
I use teak oil about once a month in the summer. Remember to also do the bottom and sides. -Tip
I use a spray bottle to get oil all over the bottom.
And every so often use a light sandpaper first,, then oil it.
Use lots of oil,, and oil it regularly.
I oil mine after every other trip.www.battlesangel.com
i found that during the season i was "oiling" my platform every 2 weeks on my last tige. on suggestion of a friend i started using cooking spray rather than the platform specific teak oil, it worked just as good. i would spray on a really heavy coat, let it sit over night and then wipe it off in the morning, it worked well but got tired of doing it so often, so i rino lined it. this is really the best way to go imo.
I like the natural look of Teak but did not like the mainetance on it nor did I want to Rhino Line it. So instead I tried Sikkens Cetol Marine and I am pleased with the results. Sikkens is a protective translucent wood finish made for boats. After a month of heavy use it still looks like the same day I applied it. The only downfall is it is slick when wet. It did come out lighter than I wanted but I dont care since I dont have to keep re applying oil. My platform was grey and faded so I started with a very light sanding and then a teak cleaner. I also applied two coats of it as well.Attached Files
I do the three step process as part of my winterizing process. During the season, I apply it abut once a month. I also use a wire brush instead of sand paper. It seems to develop small grooves in the wood that helps with traction.
The best thing for you other guys is to stay off the platform while you have a beer in your hand. Wasted beer is no laughing matter.
