I have a 2003 22v and have had it winterized by my local dealer for the past 4 years, however I want to take the time and save the money by doing it myself. Does anyone know where I can get a maintenance manual or winterization step-by-step guide for my boat?
Winterization
Not hard to do for someone that is kinda handy. Use the "search" button across the top of the page and you should find just about all you need to know.
If you have a specific ??? don't hesitate to ask.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I'm handy and plan on doing my own winterization this year as well. The dealer is 100 miles away and that's a PITA..
So, I do have one question...I use to remove the hoses to drain the block in my previous boat along with the block plugs. I would then run compressed air through the hose and further fluid would drain from the block plugs.
I have never opened the block plugs on the Ci to date. Any words of wisdom? How many? And they should be color coded I believe. I gots to go look And adding RV Anti Freeze. Just add it through one of the hoses?
TIA, Paul
Originally posted by flyboy View PostI'm handy and plan on doing my own winterization this year as well. The dealer is 100 miles away and that's a PITA..
TIA, Paul
Marine antifreeze is not necessary if you get the block and hoses drained good, but an added level of protection.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Changine oil during winterization.
Question about oil to use. I have a 2000 21i and I was told to use 5w-30 Mobile one Synthetic oil, but my books says this:
The use of non-detergent oils, multi-viscosity oils, synthetic oils, low quality oils or oils that contain solid addititves are specifically not recommentded. Will the synthetic hurt anything or should I use something else?
ThanksDale
2000 21i Tige
Originally posted by Fit to be Tige View PostWhile the boat sits over the winter, how important is it that it is level??? Where I plan to store the boat has a slight slant, but I could try to build up one side in order to get it close to level.
Thanks.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostDisconnect the intake hose at the transmission cooler to drain it and to drain the impeller/water pump and v-drive cooler.
I drained the 2 petcocks and pulled the hoses off of the impellar so that leaves the knock sensor(s)? and or plug to pull. Kind of weird that they don't have petcocks for the actual block, Mercruiser does...
Originally posted by Timmy! View PostAnyone have a picture of the intake hose at the transmission cooler? Or the v-driver cooler? I need to winterize my boat tomorrow, supposed to get down to 23 degrees over the weekend and I don't think my uninsulated storage unit is going to keep it above freezing.
I drained the 2 petcocks and pulled the hoses off of the impellar so that leaves the knock sensor(s)? and or plug to pull. Kind of weird that they don't have petcocks for the actual block, Mercruiser does...Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Timmy! View PostThanks! Now how to I get the seat bottom off so I can get to that? Does it just pull up?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostShould be able reach everything through the access cover (table mount if you have it) but you need 2 elbowsCursed by a fortune cookie: "Your principles mean more to you than any money or success."
