So what solutions have you-all found for mildew???
Our boat has been parked for two weeks because we were out of town last weekend and I got in it today and there was mildew all over the white vinyl!!!
The gray vinyl was spotless.
I have cleaned it with the 3M marine mildew remover, which worked ok. I tried a diluted bleach solution, still only worked ok. I regularly treat the vinyl with 303 protectant to try to keep the mildew off. I think it helps make the mildew more easily removed, but it is still there!!! I also don't use the tight fitting cover because it does not let the boat dry so I just use a huge tarp that covers the tower and all propped up at the ends to allow it to dry. Any help would be appreciated as always.
