Well, we've had the boat about a year and we have 200 hours on it. What particular maintenance would you-all do to the boat? I already plan on the oil, trans, and v-drive fluid changes. I also plan to do an impeller and the normal greasing of everything that can be greased to include the steering stuff. Anything I missed??? I plan to do this all on Sunday.
200 hour maintenance
Originally posted by mtnsmith View PostWell, we've had the boat about a year and we have 200 hours on it. What particular maintenance would you-all do to the boat? I already plan on the oil, trans, and v-drive fluid changes. I also plan to do an impeller and the normal greasing of everything that can be greased to include the steering stuff. Anything I missed??? I plan to do this all on Sunday.
Got any pics of you boat?The sun never sets on a badass
Originally posted by wannabewakeboarder View PostBetter check your radiatoir fluidsBetter stick with your crayola crayons and get a better handle on that noodle.
mtnsmith, I'd check your distributor cap for any signs of carbon or corrosion, you may need to replace it. Since yours is an '05, you should also think about changing your impeller. Some do that every year, but you should never let it get more than 2 years old. It tends to dry out and get brittle. Nothing like ending a good day at the lake with an overheating problem. Check your plugs and inspect your plug wires.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by mtnsmithI already planned on the impeller, I hadn't thought about plugs and cap though.
Is a fuel filter that should be changed???
The first one is our 22v; the second is my flats boat-16' Renegade, and yes we are wakeskating behind it; the third is the big boatActually not my boat, but just like my parent's, and that one is a friend's that was being loaded at the factory in Sarasota, FL so I took pics for them.
