Anyone know where I can find the oil filter part number for a 2006 20V with the 340HP GM Vortec 5.7L MPI?
Oil Filter Part Number for 2006 20V
I have the same question. I topped 20 hrs yesterday and I need to change the oil for the break in period. I want to add to the question, is there an automotive equivelant that can be used, as it is with many other GM based engines. The same oil filter in an automotive application is usually a 3rd of the cost of buying a marine oil filter which is the same thing under a different color of paint or label.I don't want to go to work, take me wake surfing instead!
The marine power manual specifically states not to use multi viscosity oil, and then says its o.k. to use 20-50. Go figure. Indmar and PCM both recommend 15-40 for the same GM 5.7l engine block. 10-40 has a lot of viscosity improvers (VI). These are polymers that are added to the oil. If you want multi viscosity go with 15 -40 (less viscosity improvers) or use the mercury marine 25-40 otherwise use the straight 30 or 40 weight. I used straight 30 sae for 20 years in a boat (350ci) and never had any problems.
I would also recommend to stay with a "Marine" grade oil as it will have more rust inhibitor, for the high moisture conditions and down time, than auto engine oil.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
"Hey," how about a drain hose for draining the oil? Does anyone know if Marine Power installs this on their engines? I have not seen one in my poking around to get familiar with my boat. Curious if there is a hose to push through the drain plug opening for easy of draining of oil. With the weath of information provided in the owners manuals I got or didn't get,(Sarcastic) I don't have any resources other than this forum to access or get answers to these questions. I do have a two way pump with the little spaghetti noodle tube to slide down the dipstick tube, but that is very frustrating to use.
Originally posted by scoot18 View Post"Hey," how about a drain hose for draining the oil? Does anyone know if Marine Power installs this on their engines? I have not seen one in my poking around to get familiar with my boat. Curious if there is a hose to push through the drain plug opening for easy of draining of oil. With the weath of information provided in the owners manuals I got or didn't get,(Sarcastic) I don't have any resources other than this forum to access or get answers to these questions. I do have a two way pump with the little spaghetti noodle tube to slide down the dipstick tube, but that is very frustrating to use.
Much quicker than draining.
You are probably right, I don't know if I can even see my drain plug opeing from the top side. It might be like theading a needle with my eye's closed. I might be able to see it better once the side panel is removed to access the oil filter. But if you have done it and say the sucker pump is the best, I will just use what I am used to. "Thanks"I don't want to go to work, take me wake surfing instead!
Here is where I found mineAttached FilesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
