Trailer Maintence
    Trailer Maintence
    Who here does yearly Maintence to their trailers?
    Just a brief list of what you do would be great. I'm just curious as I hear and see different things.
    For example,
    I fill up my bearing buddies, and give the trailer a good cleaning.
    Check the tire pressure, and tire wear, and my spare as well.
    Thanks.
    Originally posted by G-MONEY
    Don't ask me, i just said heck with it and did the whole thing!
      ha ha ha, I know, but like last year, or next year
        I fill the bearings whenever they look low
        try to keep the trailer clean as much as possible
        tire pressure every other trip
          yeah I do all that just like you do as well
            yea thats all that seems need be done
              i see young grasshopper
                Beginning of each season you should;
                • Checking bearings is a good thing at least every other year if you have bearing buddies, each year if not.
                • Check the brake fluid
                • Check the safety cables or chains for wear
                • Check the auto lockup cable for wear
                • Check the hitch cup, a light coat of waterproof grease helps things turn better
                • If you have exposed wiring then check connections and look for fraying
                • Make sure all lights are working and replace any bulbs that look weak
                • Check harness connection, make sure all pins/receptacles are clear of debris/oxidation and apply some dilectric grease to male/female connectors
                  thanks razz
                    We check all bunks, tighten the winch pole?, check tongue all wiring and safety cable stuff, and tire pressure.
                    Common Sense is not so Common
                      how often do you guys find you need to replace the carpet on the bunks? I did mine after the first year, but figured that was cuz I was coming into fast, so now i have slowed my approach and find it lasting longer.
                        Have not replaced any carpet yet, but 2 of them need to be. Trailer is on its 3rd season. We cracked a board right down the middle on our second time out.
                        Usually for bunks I just crawl around underneath and tighten all bolts.
                        Slower approach is nice.. like less than idle..little taps. We just found out we need to drop the ball down a little lower so I guess that will effect loading and unloading.
                          i wanna put straight axles on mine so my boat and trailer are not so freaking low to the ground
                            I replaced the carpet on my bunks at about the 5 year mark.
                            Check the bolts on the swing away tongue. There was a problem with them having too short of threads on an earlier post. They should be checked anyway.
                              I wish I had a swing away trailer.
