Does anyone know the recommended oil capacity of the 5.7 marine power engines from the 95-99 ish era?
Fluid Capacity
Originally posted by spharis View PostDoes anyone know the recommended oil capacity of the 5.7 marine power engines from the 95-99 ish era?
My gut says 5qts with short filter (5.5 w/long)
Heres is a safe way to not overfill when you change oil/filter: Note where oil level is on dipstick (should be in "safe" zone. Next, drain, suck, extract used oil into graduated container. Fill engine with same amount as removed and add 1/2 qt for filter or 1qt w/long.
Level should be close to where it was when you started.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostMy gut says 5qts with short filter (5.5 w/long)
Good tip though, I've never thought of going that route."I want to know God's thoughts, the rest are just details"
Originally posted by Tequilasun View PostYou mentioned Graduated container, it took me right back to my Chemistry major days. Good times.
Good tip though, I've never thought of going that route.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by David Baker View PostI've found that with remote oil filter line you have a hard time getting the specified capacity in without overfilling. My Merc 350 specifies 6 quarts with filter but if you put more than 4.5 it will overfill. My guess is the remote lines aren't draining into pan.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
