Have a few questions:
My boat is a 2004 Switch V, with the 5.7L 335 MP
First, I am trying to figure out how to drain the oil. So far, I know where the oil drain tube is, but I am a bit confused as how to use it...should I try to pump it out through the tube, or should I drain through the plug?
Second, I am trying to locate all of the plugs for draining the bloc. So far we have located the two manifold drains (left and right) and the bloc drain on the passenger side, near the bottom. We have been told there are two more, and are trying to figure out where those would be
Third, I can't find a good writeup on how to drain the ballast system completely.
If someone could help me, that would be prime.
