If the boat is floating in water, how acurite is the dipstick reading on an Indmar 5.7?
checking engine oil level while in water
That supposed to be the most accurate they sayMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Reason I ask is this. Indmar says to level the boat to check oil. While floating, neither the floor or engine are remotely level. I pumped out 5 plus quarts of engine oil and replaced with 5.5 quarts of Indmar 15w40 with new Indmar filter and fired engine. After letting set for several minutes, level looks very high. Like up into the dip stick tube high. The oil is perfectly clear and fresh looking, I do not believe any old oil had been left in the oil pan, which was my first concern. Before I had changed it, the old level of the dirty oil was at the top indicator on the dip stick like it had not used any.
Originally posted by Brianrzr View PostReason I ask is this. Indmar says to level the boat to check oil. While floating, neither the floor or engine are remotely level. I pumped out 5 plus quarts of engine oil and replaced with 5.5 quarts of Indmar 15w40 with new Indmar filter and fired engine. After letting set for several minutes, level looks very high. Like up into the dip stick tube high. The oil is perfectly clear and fresh looking, I do not believe any old oil had been left in the oil pan, which was my first concern. Before I had changed it, the old level of the dirty oil was at the top indicator on the dip stick like it had not used any.
You may need to check your boat’s engine oil regularly, especially when going on a long trip Ensure that the lug nuts are tightened and the spare tire for the trailer is inflated, the trailer should be assembled properly. It’s advisable to use stainless snap shackles rather than ratchet straps. Don’t forget to check the coupler as well. It should be locked down to the hitch ball. Make sure that there’s no spill on the master cylinder cap seal and brake fluid.Last edited by Dalton07; 10-02-2022, 04:34 PM.
