I've used the 7" buffer above, but you have to know what your doing as you can damage it faster than the dual action on will. Its also what I learned to use so I don't like dual action ones myself.
Different pads have a different amount of cutting action as well. I personally prefer wool over foam. Granted mine is no where near the bad shape the one in the video is.
I have both of those, other than being noisy, they work fine, I'm only polishing my toys so heavy repeated use isn't a requirement for me. Just make sure you have the right pads/product/technique as has been described and they get the job done.
