2007 24ve access panel removal
    could someone please tell me how to remove the access panel that covers the fuel tank. thanks
    If it's anything like my 06 22ve, remove the back seat and just lift up the floor by the vdrive. There are guides on the front that keep it down but that is it.
    "Charlie don't surf"
      On my 06 24ve you have to remove the back middle seat. To do this I have to unscrew the table mount and then undo the wing nuts that hold the middle seat to the sides. Once that is out you will expose the V drive transmission and then you should just have to lift up at the back and then slide a little to remove the floor panel. Should only take about 10 minutes but the first time it took me a while longer to figure out how to remove all the bolts. Good luck
