Hey All,
Fired the boat up for the first time about a month ago, everything seemed fine with the exception of a squeaky water pump pully. Took it apart, light coat of white lithium grease and checked all the common areas for broken, missing, worn out pieces all looked good. Spun a few times (without the impeller) and turns really well no grinding or squeaking. I put everything back together hook the belt back on assuming it was good and sure enough right back to squeaking. Is it possible to just replace the bearing inside the housing, or do I have to purchase a whole new unit? Please help, don't want to spend $350 on a new unit the $8 bearing is more in my price range.
