I have noticed that my Tige is getting brown stains on the white portion of the hull below the water line. These stains are only on the side of the hull, heavier on the port side, and not found on the bottom of the hull. I am thinking that they may be some type of chemical that is floating on the surface of the water (like an insecticide or something).
Has anyone else experienced this, and how do you clean it off. I have tried wax, buffing compound, tar and road oil remover, and simple green. None of these will get rid of the brown.
Needing help, and appreciative of all ideas,
Rodg
Rodg
