Water pump gasket
    Water pump gasket
    Can anyone tell me the part number for the main gasket in between the water pump and the engine? 2007 22 Ve'. Thanks!
    Just curious if you had issues with the water pump? I have the same make and year.
      Is it the 2 gaskets between the block and the circulation pump? If so, just go get a gasket set for a 5.7 chevy from a 97 Chevy C1500 pickup. Take the pump just to be sure. You can also buy a sheet of gasket material and cut your own if needed.
        Thanks, chp, I'll check that out.
        Skip, I've had some overheating on occasion, but then last season I noticed I had a leak on the bottom of the pump where it meets the engine block, and it got progressively worse, so now it's time to do something about it.
