Got a couple white board marks on my new boat, was wondering if there is an easy way to remove them? Have a black color boat that shows every mark. Any solutions, rubbing compounds or methods that work well without damaging or affecting the color of the boat?
wakeboard marks on side of boat?
Don't know if your marks are deep or just surface but if they didn't actual take figerglass, I would highly recommend "Mr. Cleans Magic Eraser". Get the ones with only the white pad not the combo ones where there is the white pad and a scubbing side. We found those didn't work as well. I think you will really be pleased with the Mr. Clean Magic Eraser white pads. Use them on anything you want removed. We see people trying all kinds of stuff, then we come over with these little white pads, get them a little wet and scrub, and literally like magic stuff disappears. Try them on your vinyl and you will be amazed at how well they remove little marks.
Even if this doesn't take care of your marks you will like them for everything else. This is the stuff that takes crayons off walls.
Hope this helps.
