What tire pressure do you keep in you tires? I checke mine and then are right at 40. Do I need to go to the cold max of 50?
I never know what is right. So what do all of you think?
I asked extreme trailers this years ago and they said keep it at the max posted on the tire (most likely 50). They said I could go a little bit under since my normal route is through the hot desert where they will get to well over 50 when hot. I keep mine around 45.
I know this is sort of contradictory because I believe running under pressure causes heat. Any scientists out there with straight scoop?
