I have no previous experience with DD's or VD's but am seriously looking at both. I do all my own maintenance so ease of access is important.
I've briefly looked at a used 22i and a used 22v. My impression is that the 22i would be easier to service; remove the engine cover and basically everything is right there... the engine is sitting high enough that you can almost get underneath it. Remove the rear cover and the stuffing box, rudder linkage, etc. is right there.
In contrast, the 22v seemed like everything was scrunched up and buried down under/behind the seat. The top of the engine was easily reached, but if I had to reach the sides or (yikes) the bottom there was precious little access. The bilge was WAAAAY down there. And I presume the stuffing box, rudder, etc. were down under the engine somewhere, correct? Can you repack the stuffing box, replace the steering cable, etc. without removing the engine?
Thanks for any help with my learning and planning!
