I will have a RZ4 coming weekend and I want to know how to break in the new engine?? THX
Break in method
Welcome to the Tige family. Here is a post that may help you.
http://www.tigeowners.com/forum/show...ighlight=Break
There is a specific break-in procedure for the first 5 through 25 hours in the PCM manual, my dealer went over the instructions step by step. Also make sure you fill out the warranty cards for both the boat and the engine. Welcome, I picked my boat up 3 weeks ago so I'm relatively new to the site as well, there is to s of great info here.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by somebodyelse5 View PostAnyone ever consider using some of the royal purple break in oil?and just drive the boat as you normally would, but just my opinion.
In all my years as a professionally technician, I have never know anybody that ever fallowed the break-in for their car. I've torn down a ton of engines, and not one failure could ever be contributed to a poor break in period. IMO, if the engine leaves the assembly plant correctly built, it will never fail as a result of not fallowing a breaking procedure. On the other hand, if the engine was not assembled correctly, or had a defect in an internal part, no amount of "breaking" driving will prevent the inevitable.
Proper maintainence has more to do with an engine life span then anything.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
http://www.mototuneusa.com/break_in_secrets.htm
This is a tricky subject and this website explains it very well. I was an environmental engineering major in college and not a mechanical engineer, nor am I a licensed mechanic. I did take the basic engineering classes in physics, thermodynamics and intro to mechanical engineering and this method makes sense to me. I have used it to break in my G35 and my wife's 4runner and I was surprised to read in the PCM owners manual a similar procedure to break in the engine. The basic procedure is to put the engine under load very early in its life to properly set the piston rings. This procedure makes no claims to make your engine last longer, it just attempts to set the rings to prevent loss of compression and squeak the most power possible from the engine.
I followed the PCM procedure 'cause I thought it was setting the rings properly to get the most out of the engine. Just like chpthril said, it's probably not going to cause your engine to run poorly or fail prematurely because you didn't follow the break-in procedures. It is a controversial subject that will have many strong opinions and it took a lot of surfing the web and a buddy with a masters in internal combustion engine design to convince me the procedure linked is good for my vehicles.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by chpthril View PostI would spend my money on Crown Royaland just drive the boat as you normally would, but just my opinion.
Proper maintainence has more to do with an engine life span then anything.Joey - Red 20V Riders Edition
Originally posted by Ewok View Posthttp://www.mototuneusa.com/break_in_secrets.htm
Im studying to be a mechanical Engineer, If i get to the point where I can let you guys know, I will!Joey - Red 20V Riders Edition
