Can't go over 12 mph ;) and beeps every 15 seconds
    similar issue as the other thread. Just picked up a 2004 24V with the Marine power 5.7 . I checked wires on my fuel pumps, those appear to be good.
    One additional bit of info which I didn't see mentioned in the other thread is we've got a beep every 15 seconds. Boat makes it up to about 12mph and that's it. All the gauges seem to be correct. Engine does run a bit rough otherwise. We're taking it into the dealer in Austin on Wednesday anyway for a 'buyers check'...maybe a bit late for that one
    Ideas? Does that beep mean anything specific, I found something else on here about a 30 second beep but this is definitely more frequent than that.
    Make sure the knock sensor is plugged in.
      It is, checked that based on your reply in the other thread.
        I know its a (dumb) question but how much oil do you have in the motor?
          It was fine at the time and it's since been changed...I've got a new thread going here if you have any input.
            Sorry I don't have the answer for you, but the Ski Dock will be able to hook you guys up. Will is a great guy and hopefully they have been slowing down a bit so they can get you right in.
