When I am going slow my 2006 22v seems to be perfect but when I try to speed up my motor loses power and sputters ? Any hints first time in the water this year , full tank of gas from last year is that the problem .
Can't go over 10 mph
I had this problem on my Marine Power 5.7, and it was a lose wire for the low pressure fuel pump.
(There is one wire that plugs on the very bottom of the fuel pump filter assembly. This wire just pushes on, make sure it snug. )
On my boat, if you let it ideal for awhile, the high-pressure pump could draw enough fuel into the filter to last a few minutes. Once it started to act up, that was it, you need to back down and wait or keep it at a low speed
Good luck, as I know too well this is very frustrating.
DavidTige, it's a way of life!
Originally posted by Joss View PostWhen I am going slow my 2006 22v seems to be perfect but when I try to speed up my motor loses power and sputters ? Any hints first time in the water this year , full tank of gas from last year is that the problem .Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I talked to the dealer and they say that they put additive in the gas . Went for drive after checking the wires no my fuel gages saying empty is was reading full ! Maybee It read full last season and it was empty when I winterized it does the boat have a limp mode if the fuel is low. I wish the boat elves just would have fixed it in my sleep.
Originally posted by da.bell View PostWhen you go over 10 mph, does the engine die?
MAP sensor????? What do you think Chpthril????
One thing we dont know.....did the mechanic run the engine after adding the stabilizer, so it had a chance to reach the fuel rail and injectors, or did he just pour it in the tank?
The only other thing is could something be left off/undone from the winterization? Is it a Marine Power? Is the knock sensor connected?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Joss View PostYes it is marine power and where would I find the knock sensorMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Joss View PostI checked the connection it seems fine but the sensor looks a little rusty it still is powering down . I will buy a new one tomorrow and see if that works. What is spark knock it was making some loud nocking noises right before it would power down.
I dont think you are dealing with an overheating condition, but a lean condition is a possibility. Some of the causes: low fuel pressure, water in fuel, poor fuel quality (spoiled fuel), restricted injectors (spoiled fuel that has left deposits) faulty MAP or TPS sensor, plugged fuel filter (more then likely water), large vacuum leak (would idle like crap).Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
