I changed my oil this weekend and the drain line that is connected on the bottom of the pan is long enough to go out the bilge drain hole but the oil drains onto the TAPS plate and makes a mess. The drain line should be longer to hang off the TAPS plate, about 6 inches.
So I went to the hardware store got some fittings and some hose and made it longer.
