As said previously, on labor date a floated over a submerged tree, engine off going 5 mph, it slightly bent one of the props tips, take it to the local marina, they have a prop puller, that was way to big and they try to remove it, the end up causing more harm than good so after about 15 minutes of increasing nicks and dings in the prop they give up as well as I. I ordered the ACME c clamp prop puller, followed the instructions to a tee and still the prop is stuck. I tried everything, from real tight, to real lose, to hitting it to get the most harmonic, crawling under and using my legs to push on the prop, to rotating the puller and repeating every combo for over an hour.
My next step is to get some penetrating oil, if that fails, then thinking of heating it up with a butane torch.
Am I missing something here.
This is the second prop that I have bent, the first one much worse, but at a very slow speed, the same marina, used the same oversized puller, and after using a break bar finally got it off. I framed houses so I can swing a hammer, but I am running out of options.
Any thoughts of taking an impact wrench to the prop puller nut and going for gusto.
This has delayed me the last two weeks, only 1-2 more of the season left.
